Licensing Error Issue Monarch Classic
User: "Ken Lindsay"
Altair Community Member
Updated by Ken Lindsay
I need some help resolving a licensing issue. The error reads:
Unknown error occurred
Altair Managed Licensing: License Error
Feature: Monarch Classic
Error Code: 1
Error Description:
Invalid config file
1 - 3 of 31
    User: "Julia Cobb"
    Updated by Julia Cobb
    I just encountered this issue and accidentally solved it. After generating the auth code in your altair one portal, use it to authenticate on the first tab THEN second tab of license manager. I was only doing the 2nd tab (since that's where the warning sign was) and skipped the first tab, which appeared fine.
    User: "Derek Moore_21075"
    Updated by Derek Moore_21075
    I'm getting this error and cannot proceed to the licensing screen to correct the issue, Monarch does not launch.  How do I fix this if I cannot get the program to launch?
    User: "Julia Cobb"
    Are you launching Monarch or the License Manager? You have to active the license in "License Manager", which should launch regardless of an active license or not.
