In Starting HyperWorks with the new GUI.
User: "Andrew Cave"
New Altair Community Member
Updated by Andrew Cave
In Starting HyperWorks with the new GUI I get the following error message 'HyperWorks has encountered an error and must close'. How do I resolve this issue?
I have installed both 2020 and 2022.3 on my Windows 10 laptop and both come up with the above message while attempting to start using the new HyperWorks GUI.
1 - 2 of 21
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Hello,
    Does Legacy open fine?
    If yes, it is possible an update to another software (such as webex) is causing an issue with Hyperworks writing to the boost_process folder.
    You can check this by shutting down webex and trying again.
    The Hypermesh 2023 version should not exhibit this behavior anymore.
    thanks
    jason
    User: "Andrew Cave"
    OP
    Thanks. That solved the issue, it was Webex. Version 2023 is now installed and opens without an issue.
