Matze,
What exactly are you trying to model here?
Is it creep? In RADIOSS LAW42 you can prescribe shear modulus as function of time G(t). The function should be represented as prony series. Coefficients shall be fitted according to creep or relaxation test
See Altair RADIOSS > Reference Guide > Starter Input > Starter Keywords > /MAT:
/MAT/LAW42 (OGDEN)
I am aware of these LAWs, my problem is that they are at best dependant to heat, though I need to somehow create/find an orthotropic material which is dependant to time. More precise for an solid object and with a change over time for the values of he Young's modulus, the shear modulus and the Pioson's ratio.
Matze,
Since this is carbon epoxide and we can use LAW25 and /VISC/PRONY to simulate time dependence.
Of course you should understand that Radioss is an explicit code and we can not do simulation for 30h end time.
You will have to scale the time to some smaller value and simulate it quasistatically.
Matze,
you will have to add the /VISC_PRONY card manually in the 0000.rad file,
Open this file in a text editor and enter the parameters and save the file before running,
As a reference of how the card should look like, Look at the card syntax in help and perhaps you can also export the card with a law 66, look at this in a text editor and replicate this for a law 25 by manually editing the starter file (0000.rad) in a text editor.
Which parameters do you want to be changed over time?
Is there anything else as a reference except time?
Regards,
Manuel.
