1 - 9 of
91
this is my file. if you mesh it, I will be appreciate to get the hint from you. thanks alot
one of my problem is I could not change the quality of the layers' mesh because I got this mesh from point clouds and I did not have the surface from them. I tried to sketch the surface from FE for meshing it myself, but the surfaces does not have much quality because of the complexity of the geometry and the meshes. I do not have any more idea. and I will be appreciate if you could help me.
This is not a bug.Before converting mesh into tetras, please make sure that the 2d surface mesh should be enclosed.If possible share hm file to check same at our end.
