🎉Community Raffle - Win $25
Join and Win
How to change working directory
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
My objective was to take images of components and save it in a folder.
I used the following command to take the image
*jpegfilenamed $compname
But the problem is it is saving all those files in 'MY DOCUMENTS' which is working directory.
hm_info -appinfo CURRENTWORKINGDIR
By using the command i can able to retrieve the working directory.
I used the following command to change the working directory but it is not working
set CURRENTWORKINGDIR 'C:\folder'
Help me on this.
1 - 7 of 71
    User: "tinh"
    Altair Community Member
    Updated by tinh
    hi Karthi
    use 'cd' command
    cd 'C:/folder'
    but you already use *jpegfilenamed so it's better to direct path in filename:
    *jpegfilenamed 'C:/folder/$compname'
    Altair Employee
    OP
    Thanks for the Reply!!!
    I have to check if component is not there it has to come out of the program.. For that i used the following command.
    if {$comp == ''} {
    break
    But it is showing a  HM error message as    ' invoked 'break' outside of a loop '
    it should not tell any error message it should come out without it..
    User: "tinh"
    Updated by tinh
    hi,
    the error is invalid using of 'break'
    you ough to use 'return'
    Altair Employee
    OP
    I need to use the translate option like moving the elements in mark 1 from N1 to N2
    Ex:
    *createmark elements 1 displayed
    *createvector  1 0.7085 -1.6000 0.0001
    *translatemark elements 1 1 0.2
    Like this it is coming in CMF file. how do i get the vector for 2 nodes.
    I also want to get the coordinates of a node. when i try the following option it is saying it can be used only for points.
    hm_getcoordinates points 1
    How do i create the points for the nodes in mark.
    Thanks in Advance!!!
    User: "tinh"
    Updated by tinh
    hi,
    to get coordinates of a node you can use hm_nodevalue:
    foreach {xcoord ycoord zcoord} [expr [hm_nodevalue $NodeId]] {}
    and from coordinates of 2 nodes you can get a vector by (x2-x1) (y2-y1) (z2-z1) (or using utilitiy function in hwat - please look at help about hwat)
    Altair Employee
    OP
    Thanks.. i got the coordinates.. but the problem is i need the X,Y,Z values in different variables ..
    set cor [hm_nodevalue $nodeId]
    set x [lindex $cor 0]
    set y [lindex $cor 1]
    set z [lindex $cor 2]
    When i use this i m getting the whole X,Y,Z in Variable x itself. Help me on this!!!
    Altair Employee
    OP
    Sorry i did't use the full line before... i got it thanks...
