Geometric non linear analysis - temperature
Altair Community Member
Updated by Enrico_20294
Hi,
I'm modeling a stiffened sphere subjected to external pressure and to expansion due to high temperature.
I performed a geometric non linear simulation considering only the external pressure and now I'd like to evaluate the effect of the high temperature.
How can I include it in the analysis?
I can't find nothing similar to the TEMP entry of the linear static
Thanks,
Enrico
1 - 3 of
31
Updated by Altair Forum User
Hi Enrico,
Instead try LGDISP which activates geometric large displacement analysis with analysis type NLSTAT
Hi @Enrico
What is the analysis type are you using?
If you are using NLSTAT as analysis type you can add temperature load to the subcase as shown in the image below:
