Analysis ERROR6531
AJ_21010
AJ_21010 Altair Community Member
edited July 2023 in Community Q&A
Hello,
I would like to optimize a rather complex component with my student license of Inspire and check the displacements. However, after successful optimization, the subsequent analysis aborts with the following error:
In the execution folder I can find the following message under this error:
*** ERROR # 6531 ***
 The slave of CONTACT 1 is defined on element(s) with incorrect
 node numbering (e.g., element 1547292).
I would be very happy if someone could explain me where the error is and how I coud fix it. I'm running out of time.
Thanks in advance
Kind regards
AJ
Welcome!
Answers
  • AJ_21010
    edited April 2022
    Addition:
    Oddly enough, when you run the analysis using the analysis button, it runs through successfully (green flag).
    Then an exclamation mark appears and it says that the analysis is incomplete.
  • AJ_21010
    edited April 2022
    Can't anyone give me some guidance?
    I am slowly running out of time.
  • Yurillo
    Yurillo Altair Community Member
    edited September 2022
    Hi,
    I guess it's a bit late for you, but I had the same issue which was due to a heavily distorted element among the ones I created contacts on.
    Remeshing the faulty components solved the problem.
    Yuri
  • Maxime Brabant
    Maxime Brabant Altair Community Member
    edited July 2023
    Hello,
    I had the same issue and I succeed not to remesh my parts.
    I have shell elements (QAXI), thus I reversed the normals, then I renumbered the nodes, and It worked !
    I hope it could help.
Welcome!
Welcome!
