multi-material topography optimization
Reza Karshenas
Reza Karshenas Altair Community Member
edited November 2023 in Community Q&A
Hello everyone,
I have 2 questions:
1. is it possible to apply a Topography Optimization also for 3D Model or this is only for 2D Models.
2. is a multi-material topography optimization also feasible for Optistruct? If so, is there an example somewhere?
Thank you for your help
Best Answer
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    edited November 2023 Answer ✓
    Hi  Reza Karshenas,
    Below is the answer for your questions.
    1. It is possible to do Topography optimization for 3D models provided you need to have a shell element layer around the solid which need be considered in DTPG card as design variable. You can follow the below example for reference.
    OS-E: 3035 Surface Optimization of a Control Arm (altair.com)
    2. Usually, Multi material Optimization is preferred for Topology Optimization.
    Thanks....
Answers
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    Hi  Reza Karshenas,
    Thanks....
Welcome!
Welcome!
