Error at Import of an airbag-modell into HyperMesh
User: "muemarc"
Altair Community Member
Updated by muemarc
Hi there,
for my bachelor thesis, I need to add an airbag-model in a existing car-model. But when I try to import the model I always receive the error: Error reading from feinput process.
I started wondering myself, if the model, which is a .xml Madymo-file, is compatibel with HyperMesh, or if there are other mistakes?
The file is attachted to this request.
Thank you very much for your help.
Kind regards,
Marco Müller
1 - 12 of 121
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi muemarc,
    Which version of Madymo solver you are using?
    Thank you
    User: "muemarc"
    OP
    Updated by muemarc
    I am using the Madymo70 solver.
    Altair Employee
    Hi muemarc,
    Which version of HyperMesh you are using? Did you trying importing this file in 13.0 or older versions? In the current versions i don't think Madymo .XMl files are supported.
    Thank you
    User: "muemarc"
    OP
    Updated by muemarc
    Currently I am using the 14.0 version.
    Thank you very much, I will try it on older versions.
    User: "muemarc"
    OP
    Updated by muemarc
    I tried to import the file in several different versions, but I always receive the same error message.
    Do you maybe know that else could be the problem?
    Thank you very much.
    Altair Employee
    HI @muemarc
    From the Madymo file I can see that you are using a V7.4 release
    This may not support in the current version of HyperMesh. In HyperMesh, we support till V 7.0
    You can change the format in text editor to import the file. I made changes to the file and here is the attached,
    But export may not be possible as some entities are not supported.
    Altair Employee
    User: "muemarc"
    OP
    Updated by muemarc
    Thank you very much for the quick reply.
    The error message doesn't occur anymore, but instead a window pops up with the message:
    A segmentation error occured.
    Do you want to save your model?
    Best regards,
    Marco Mueller
    Altair Employee
    Can you delete the setting files and try again?
    User: "muemarc"
    OP
    Updated by muemarc
    Yes, but I still get the same result.
    Thank you
    Altair Employee
    Hi,
    I am able to open the same in 2017.2 but in 14.0 I have the same issue.
    Can you update to 2017.2 and check if that helps?
    User: "muemarc"
    OP
    Updated by muemarc
    Awesome it works, thank you very much!
    For my bachelor thesis I now have to implement this Madymo airbag-model into a LsDyna car-model. Is this possible?
