🎉Community Raffle - Win $25
Join and Win
Mapping Elements to Surfaces for Symmetric Plies
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello everyone,
I have a question that I don't know if it's possible to solve this way but, here it goes anyway.
The model I'm trying to optimize using Optistruct is a wing loaded with a pressure on its top skin. It has a symmetry plane along the XZ axis. You can see this below:
<?xml version="1.0" encoding="UTF-8"?>base_geometry.thumb.png.cece4cb46df3b4adbce4b537188c3f1a.png
This is the base geometry of the wing imported to Hyperworks through an STP file.
<?xml version="1.0" encoding="UTF-8"?>50051645_symmetryplane.thumb.png.fafe9ffe981c13bad702276ff7defd1d.png
Here, you can see the symmetry plane displayed on CATIA.
__________________________________
The load is a pressure that I apply on the surfaces I want and then I map them to the nodes corresponding to the surfaces using BC -> Loads on Geometry
See below:
<?xml version="1.0" encoding="UTF-8"?>84307950_loadstomap.thumb.png.d4c31a069931c7f7af283eaa4c413e5a.png
The pressures applied to the surfaces
<?xml version="1.0" encoding="UTF-8"?>2012590402_mapedload.thumb.png.4905b768a0040579d88b0de02f303c4b.png
The mapped loads after using BC -> Loads on Geometry.
After running a free sizing optimization the result I get for the plies is not completely symmetric (although I constrained my design variables to be symmetric). See below:
<?xml version="1.0" encoding="UTF-8"?>530692030_ply102200onhw_presmooth.thumb.png.2bf668accfbd30339f357944949e270a.png
As you can see, to the edge the ply is definitely not symmetric.
So, what I would like to know is:
Is it possible to, first, mesh half the surfaces and then duplicate half the nodes using the symmetry plane; After this I would like to map the symmetric nodes I created to the existing half surface that was not meshed so I could apply the pressure load to the full surface and then map it to the existing nodes.
The goal is to have a completely symmetric mesh so that maybe Optistruct has an easier time creating symmetric plies.
Thank you very much!
Gonçalo Pimenta
