🎉Community Raffle - Win $25
Join and Win
Extracting Bolt (Beam) forces for Bolt Calculations
User: "darad"
Altair Community Member
Updated by darad
I've created an solved a small assembly with bolted connections, with its contacting face 'separated' for the bolt calculation.
Question:  How can I extract  bolt forces (Axial, Y-shear, Z-shear) for entry into the spreadsheet.
Comment:  When using the Property feature to create Beam properties, the Calculate function computes the four entries with minus (-) sign, which had to be manually edited to (+) sign for Optistruct to solve.   I had simply entered the value for R2, but not R1.   (SimLab 2017)
