Geometric files opening in the Hypermesh
Leonardo Panicali Carlech
Leonardo Panicali Carlech Altair Community Member
edited June 2021 in Community Q&A
Hello!
I've used the Hypermesh 2021, but I didn't get the file.step in my machine. I've got opened it inside of ABVIEWER 14 NORMALLY and the same file was opened by my friend normally.
The following message is:
I don't know why! I have tried all the time! My friend opened it normally in your machine. Could You help me, please?
Best Regards!
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    Leonardo,
    try changing your folder from 'Área de Trabalho' to another, with no special characters, and check if it works, please?
    Avoid folders with spaces and special characters like this, ok?
  • Leonardo Panicali Carlech
    edited June 2021
    Leonardo,
    Hi Adriano,
    Now, I have done your tip certainly, but I didn't sucCEED. The problem was the same before commented.
    Leo.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    Hi Adriano,
    Leo.
    can you double check if your installation .exe file is not corrupted?
    Sometimes when downloading the software, for some reason the installer get corrupted and thus the software doesn't work properly.
    Even reinstalling will give you an error, since the installer was the problem.
    So first of all, please check your installer file (.exe) and check the 'checksum' value that can be obtained from your initial email.
    For more details, check::
    https://community.altair.com/community?id=community_blog&sys_id=98f4a4d4dbf060d0e8863978f49619ff&view_source=searchResult
Welcome!
Welcome!
