🎉Community Raffle - Win $25
Join and Win
Solid hole and washer
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
I need some help about washer feature in HyperMesh. I have a solid with a hole, imported into HyperMesh from CATpart file. Is it possible to create a washer around this hole?
I did some effort, but in the autocleanup file, HyperMesh gives option for washer only in surface holes.
If I try to create washer around the hole after meshing the face containing the hole (from Utility -> Geom Tools -> Washer) by selecting the lines at the mouth of the solid hole, HyperMesh shows an error: The selected line is not a free edge.
Certainly, this line is a shared edge between the surface of the face and the surface of the solid hole, therefore: does it mean that HyperMesh washer is only for surface holes?
1 - 2 of 21
    User: "raju mandal"
    Altair Community Member
    Updated by raju mandal
    You can try this
    Go to Geo panel - Quick edit panel (F11) - Select washer option and give the offset value. Now select the line of the whole. It will create waher of specified dia on surface of the solid
    User: "tinh"
    Updated by tinh
    Hi all,
    Hi Mubeen
    Sure, washer creation is for surface holes
    You can detach the surface inside hole so you get 2 free-edge at top and bottom of hole, make washer for those 2 free-edge and map 2D washers to get 3D washer
