Automatic property creation
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey Guys!
I have many components in a model (more than 300) and I have to make property for each one of them. The problem is that creating properties and rename them by components and assign them to components takes to many time. Names of the components are the item numbers, so I want to keep them and don't rename them. I have already figured out that in Utility browser there's a function, named 'auto property creation', which renames the properties to the names of the components if they are assigned before.
Do you have any idea how could I create so many properties and assign them to components in a few easy steps or do you guys have script or any other solution to solve this problem?
Thanks for answers in advance!
Best regards,
Tüki
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    please try
    - create one sample property, example PSHELL (name is not important)
    - assign it to all of your 300 comps
    - isolate only the 300 comps
    - click 'auto property ' on utility tab
    Altair Employee
    OP
    Hi,
    please try
    Hi tinh!
    Thanks for answer, it works. 'Auto property creation' makes materials to properties too.
    Thank you for your help again!
    Tüki
    Altair Employee
    OP
    Thanks so much Tinh, it works perfectly!!!!
    User: "Triyan Pal"
    New Altair Community Member
    Updated by Triyan Pal
    Hey Everyone !
    Could anyone tell me where do we use automatic skin generation factor in Fatigue analysis (FATPARM card) & under which conditions.?
