Hide elements in animation? [SOLVED]
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I want to hide certain elements from the animation by using parameters.
For example, hide elements with stress < 10MPa.
How to do this in HyperView?
1 - 2 of 21
    User: "Mario_21478"
    Altair Community Member
    Updated by Mario_21478
    Hello,
    try the following:
    • plot contour
    • go to panel 'Mask'
    • select 'Entities: Elements'
    • go to element select dialog (press mouse on Elements)
    • select 'By Contour'
    • select Value, enter your expression e.g. <50
    • select Add
    • select Mask Selected
    Hopefully it helps...
    Best Regards,
    Mario
    Altair Employee
    OP
    Thank you for your answer Mario! I don't have access to HM now, but will check and let you know if I don't get it.
