Warning while importing files (Referenced components not found
I am getting the following error while importing an fem containing connectors and contacts along with the mesh. What should I be checking here? It is creating 8 Undefined components. How to know where these components are being referenced?
Warning: Referenced Component with ID 15309 not found
Resolution: Created undefined Component with ID 15309 with default attributes
Warning: Referenced Component with ID 2584 not found
Resolution: Created undefined Component with ID 2584 with default attributes
Warning: Referenced Component with ID 2585 not found
Resolution: Created undefined Component with ID 2585 with default attributes
Warning: Referenced Component with ID 15321 not found
Resolution: Created undefined Component with ID 15321 with default attributes
Warning: Referenced Component with ID 25744 not found
Resolution: Created undefined Component with ID 25744 with default attributes
Warning: Referenced Component with ID 25745 not found
Resolution: Created undefined Component with ID 25745 with default attributes
Warning: Referenced Component with ID 17629 not found
Resolution: Created undefined Component with ID 17629 with default attributes
Warning: Referenced Component with ID 17630 not found
Resolution: Created undefined Component with ID 17630 with default attributes
Summary:Feinput finished with 0 errors and 8 warnings.
