Trying to Import Pressure Load from a .csv File and Radioss
Hello
I'm trying to import a pressure field that I obtained from a CFD solver. This pressur field is registered in a 4 columns .csv (x,y,z,P). In Hypermesh, I go in Analysis and then pressures. here I select my faces and the option "Linear Interpolation" . Therefore I choose my .csv and at first sight it seems to work. However, once in Radioss, my Pressure Load doesn't appear in the *_0000.rad file.
Do you know how could i solve this issue? Thanks in advance.
Hi,
Thanks for your answer. However, i'm quite new using Radioss so this is not very clear. I'll try to be more precise. From my CFD solver, I got dynamic pressure from each node. I store this in a file for each time step. I can enclose the file if needed. Therefore, I want to asign the dynamic pressure applied on each surface in Radioss and if possible uploading each time step, to observe the effect of sloshing on my surface. Is this possible?
Thanks in advance,
Romain Megret
Hi Romain,
I see that you have posted the same question in Customer Support Ticket CS0728062, which has already been assigned to an Altair Employee.
To avoid duplication on our part, we will proceed with support activities on the ticket.
Thank you,
Nolan McPartlin
Altair/Siemens Support
Hi Romain,
Thank you for contacting the Altair Community. My name is Nolan McPartlin and I will be helping you with this question.
In Radioss, /PLOAD can only vary with time. To map a static pressure field from the CFD solver to Radioss, individual /PLOAD cards must be generated for each element. This can be done with a HyperMesh tcl script or Python script.
Does this help?
Thank you,
Nolan McPartlin
Hi Romain,
Thank you,
Nolan McPartlin
Hi Romain,
Does this help?
Thank you,
Nolan McPartlin
