Run Optistruct from Linux results in error
Hi everyone,
I'm just getting started with Optistruct and I have some questions regarding running it from the command line.
When I do:
$/home/azanella/2024.1/altair/hwsolvers/optistruct/bin/linux64/optistruct_2024.1_linux64 "test.fem"
I get this error: error while loading shared libraries: libcublasLt.so.12: cannot open shared object file: No such file or directory
I don't get why would it need libcublasLt to run.
If I run it with: /home/azanella/2024.1/altair/hwsolvers/scripts/optistruct "test.fem"
It starts running but I still get this: /home/azanella/2024.1/altair/hwsolvers/scripts/optistruct: 320: [: optistruct: unexpected operator
Can someone explain to me what command I should give and why do I get these errors?
Thank you so much! 😀
Alice
Hi,
I think you need install some lib in your system.
What Linux distro do you use?
NDQ
