- PARAM, LGDISP,1 is used to activate large displacement analysis for all subcases containing the NLPARM or NLCTRL Subcase Information Entry in the model. Subcase-specific Large Displacement Analysis can be activated via NLPARM(LGDISP)=SID, wherein, SID references a NLPARM Bulk Data Entry.
Hello
You can define it in the SUBCASE
Or activate it in the PARAM card
https://help.altair.com/hwsolvers/os/topics/solvers/os/param_lgdisp_bulk_r.htm?zoom_highlight=lgdisp
I am not sure I understand your question?
By using the NLPARM (LGDISP) you are activating the large displacement model.
In subcase definition when I click on NLPARM LGDISP, I get option to select loadcollector.
In loadcollector I am unable to see option for LGDISP shown in images above.
I seem to recall this was an issue that has been resolved. Can you please try updating to a newer version and see if you see the same behavior?
We tried to apply hotfixes from snapshot below.
The issue is still there.
I am not able to reproduce the issue
I would either disable filtering or trying deleting temporary settings files
Filtering is removed but I am still getting the same issue. I will ask company admin to remove setting file as I don't have permission to do it & come back to you if the problem is still there.
Hello
