Executing Tesseract
I am trying to execute Tesseract to extract detail from PDF's that have been converted to PNG. Any idea why I am getting an error 127 when I am able to execute via terminal?
<?xml version="1.0" encoding="UTF-8"?><process version="9.10.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.10.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.10.000" expanded="true" height="103" name="Loop Files" width="90" x="179" y="85"> <parameter key="directory" value="/Users/robinmeisel/Dropbox/master_png/Autoseis"/> <parameter key="filter_type" value="glob"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="true"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="9.3.001" expanded="true" height="68" name="Create Document" width="90" x="112" y="136"> <parameter key="text" value="tesseract %{file_name} %{file_name}.txt"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:write_document" compatibility="9.3.001" expanded="true" height="82" name="Write Document" width="90" x="246" y="136"> <parameter key="file" value="/Users/robinmeisel/Dropbox/master_png/Autoseis/tesseract.sh"/> <parameter key="overwrite" value="true"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="productivity:execute_program" compatibility="9.10.000" expanded="true" height="124" name="Execute Program (2)" width="90" x="380" y="136"> <parameter key="command" value="chmod +x tesseract.sh"/> <parameter key="log_stdout" value="true"/> <parameter key="log_stderr" value="true"/> <parameter key="working_directory" value="/Users/robinmeisel/Dropbox/master_png/Autoseis"/> <list key="env_variables"/> </operator> <operator activated="true" class="productivity:execute_program" compatibility="9.10.000" expanded="true" height="103" name="Execute Program" width="90" x="514" y="136"> <parameter key="command" value="./tesseract.sh"/> <parameter key="log_stdout" value="true"/> <parameter key="log_stderr" value="true"/> <parameter key="working_directory" value="/Users/robinmeisel/Dropbox/master_png/Autoseis"/> <list key="env_variables"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_op="Execute Program (2)" to_port="through 1"/> <connect from_op="Execute Program (2)" from_port="out" to_op="Execute Program" to_port="in"/> <connect from_op="Execute Program" from_port="out" to_port="output 1"/> <connect from_op="Execute Program" from_port="err" to_port="output 2"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <connect from_op="Loop Files" from_port="output 1" to_port="result 1"/> <connect from_op="Loop Files" from_port="output 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
1 - 3 of
31
@sgenzer or @ey can you help here?
1 - 1 of
11
which tesseract
/usr/local/bin/tesseract
use the path inside of the Create Document operator
