2D Mesh Boolean
Hello All,
I want to perform 2D mesh union operation of two set of overlapping elements. Below are the images for reference.
Here, both mesh A and B consist of 2nd order tria elems. Mesh A is from an older FE model built in different pre-processsor (Abaqus CAE) and Mesh B was generated within HM. The objective is to preserve mesh-A and stitch the extra mesh region present in the mesh B to it.
I have tried using the mesh Boolean operation, but did not get any solution. Not sure if I am missing out something.
So, is there a way to achieve this ? I am open to tcl scripting as well.
Thanks,
Roshan
Hi,
perhaps mesh imprint functionality can be utilized.
https://altairuniversity.com/wp-content/uploads/2017/10/Mesh_Imprint.pdf
https://connect.altair.com/CP/SA/training/self_paced/aero_v13/PDF/chapter5_demonstration.pdf
The operation can be done manually.
