problem on install R extension : incompatible extension during statup
1 - 9 of
91
Hi,
this is indeed a strange error. Perhaps something during the download or registration of the extension went wrong.
My not so creative suggestion would be, that you remove the extension *.jar file from the .RapidMiner/managed folder. It's name should be rmx_r_scripting-8.1.0.jar and then try to install it again from the marketplace.
Best,
David
hi @maryam_raz21 - could you please share your log file (go to .RapidMiner and grab the file called "rapidminer-studio.log") so we can take a look? This is by far the best way we can help in this kind of situation.
Scott
This article should help you in setting up your Studio to embed R script in RapidMiner.
Embedding R script in RapidMiner
Hope this helps.
Cheers,
Hi,
what edition of RapidMiner are you running? And can you have a look into your .RapidMiner folder, there is a file called rapidminer-studio.log. This should contain more details.
Cheers,
Martin
