1 - 7 of
71
Sometimes the meta data doesn't propogate so the names don't show up. One way to fix this is as the solution suggest, toggle on Sync with MetaData preference. If that doesn't work, I'd inspect your data to see why the metadata is not propogating and try the Guess Types operator to see if it can resync things automatically.
1 - 1 of
11
It's not the end of the world. Sometimes the meta data doesn't synchronise. In this case it's probably because SQL is at the far end.
The workaround is to type the names of the attributes.
