strange java error for simple loop files process
I have a simple process where a loop files operator reads a directory of SPSS data files and then converts/writes them as csv files. The process appears to work fine for some directories, but for other directories it generates an unexplained "process failed" error. It seems to be some kind of java error, but I am not sure why this process is working in some cases and not in others. All the directories are in the same general location but are just different subdirectories. The information from the log file is shown below. Any help would be appreciated.
Apr 06, 2016 9:55:40 AM com.rapidminer.Process loadInitialData
INFO: Loading initial data.
Apr 06, 2016 9:55:40 AM com.rapidminer.Process run
INFO: Process //BrianRepository/Learning/Misc/convert SPSS files starts
Apr 06, 2016 9:55:41 AM com.rapidminer.gui.ProcessThread run
SEVERE: Process failed: operator cannot be executed. Check the log messages...
java.lang.IndexOutOfBoundsException
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:255)
at com.rapidminer.operator.io.BytewiseExampleSource.read(BytewiseExampleSource.java:127)
at com.rapidminer.operator.io.BytewiseExampleSource.read(BytewiseExampleSource.java:119)
at com.rapidminer.extension.file.connectors.operator.io.SPSSExampleSource.readStream(SPSSExampleSource.java:335)
at com.rapidminer.operator.io.BytewiseExampleSource.createExampleSet(BytewiseExampleSource.java:84)
at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:49)
at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:33)
at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:126)
at com.rapidminer.operator.Operator.execute(Operator.java:1000)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:50)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:798)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:392)
at com.rapidminer.operator.meta.AbstractFileIterator.doWorkForSingleIterationStep(AbstractFileIterator.java:128)
at com.rapidminer.operator.meta.FileIterator.iterate(FileIterator.java:103)
at com.rapidminer.operator.meta.AbstractFileIterator.doWork(AbstractFileIterator.java:109)
at com.rapidminer.operator.meta.FileIterator.doWork(FileIterator.java:59)
at com.rapidminer.Process.run(Process.java:1071)
at com.rapidminer.Process.run(Process.java:973)
at com.rapidminer.Process.run(Process.java:926)
at com.rapidminer.Process.run(Process.java:921)
at com.rapidminer.Process.run(Process.java:911)
at com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
Apr 06, 2016 9:55:41 AM com.rapidminer.gui.ProcessThread logProcessTreeList
SEVERE: Here:
SEVERE: Process[1] (Process)
SEVERE: subprocess 'Main Process'
SEVERE: +- Loop Files[1] (Loop Files)
SEVERE: subprocess 'Nested Process'
SEVERE: ==> | +- Read SPSS[1] (Read SPSS)
SEVERE: | +- Write CSV[0] (Write CSV)
SEVERE: +- Loop Zip-File Entries[0] (Loop Zip-File Entries)
SEVERE: +- Read SPSS (2)[0] (Read SPSS)
SEVERE: +- Write CSV (2)[0] (Write CSV)
SEVERE: Here:
1 - 2 of
21
I ran across similar issues with some files (not SPSS, but a similar sounding loop) several projects & years ago.
It turned out to be some of the files not converting well enough.
The way I worked around it was to put my operations inside a Handle Exception operator and for any files that fail to move & rename them file into a new directory marked errors.
Then I could go through at leisure all the failed ones until I found out where the problems were. In your case as you will be on professional support for Read SPSS you can get RM to help with that.
if you're using the SPSS operator, you should have access to our professional support, right? Please contact us there as this question certainly can't be answered by other community members
Regards,
Marco
