"Cannot register operators from NoSQL" - MongoDB Operators
Hi! I'm trying to run a process, in my java application, with operators of MongoDB (I want read data from a mongo database). I got the following errors:
"Register plugin: NoSQL
Register plugin: Text Processing
Cannot register operators from NoSQL: Extension dependency not fulfilled! Missing extension rmx_jdbc_connectors with minimum version 6.5.0.
The operator class 'nosql:mongodb_document_reader' is unknown. Possibly you must install a plugin for operators of group 'nosql'.
UserError: The dummy operator Read MongoDB (replacing nosql:mongodb_document_reader) cannot be executed. "
Both plugins are up to date (version: 6.5)... I can't find any file starting with "rmx" in RapidMiner folder.
In the RapidMiner Studio (6.5.002) runs well. I already tried run the process on server (2.5.3), but I got the same error:
"com.rapidminer.operator.UserError: The dummy operator Read MongoDB (replacing nosql:mongodb_document_reader) cannot be executed."
Thank you
Thank you
1 - 5 of
51
you can simply download it from the marketplace web interface:
https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_nosql
~Martin
~Martin
Since you are running server, you have a licence. In this license you always get a support contract. I would recommend contacting our professional support at support.rapidminer.com
One thing I might add: Have you configured your server? you need to set the path to the plugins folder.
~Martin
~Martin
did you install the extension on Server?
~Martin
