[SOLVED] READ DOCUMENT II (MAIL)
User: "dara"
New Altair Community Member
Updated by Jocelyn
Ok after you get the READ DOCUMENT MAIL working as indicated in the earlier post, then there is still a problem.
If there is no incoming mail in the INBOX an error message appears:
\PROCSS FAILED
COULD NOT CREATE META ATTRIBUTES
Translation: Mailbox empty.
Q: How could I capture this exception and handle it properly????
1 - 2 of 21
    User: "Nils_Woehler"
    Hi Dara,
    you could use the Handle Exception operator which gives you an option to do something else in case of an error.
    Best,
    Nils
    User: "dara"
    OP
    IT WORKS!!!!!!!! thank you Nils
    D
