1 - 4 of
41
Hi George!
I'm not sure if you understood my correctly: After segmenting an object from a CT and importing it to hypermesh I have a certain size. When I measure a distance with F4 how do I know the units of this measurement? And how do I make sure that this is the correct size? What is the standard way to make sure that the sizes correspond to the CT?
Thanks for your help!!
Best, Jonas
Hypermesh displays distance based on unit system you have followed in CAD software.If it is not correct, then while importing files you have option to scale geometry.
If modelled using inches & in Hm, if you want mm then give scale factor of 25.4.
For STL files you can use Tools : Scale option for scaling surface or solid.
Hi,
You have to use the Distance panel (F4) to determine the distance between two nodes/points and thereby has to maintain a consistent unit system.
Attaching is the normal unit consistency followed across industries.
