Hello All,
Can we define Pbush property with RBE2 element of is it only defined for CBUSH (spring) element.
Regards
Pratik
Hi Pratik,
what is the use case?
Do you want to make the spring as a rigid using PBUSH property?
if that was the case, you can use RIGID in PBUSH card.
Pbush is specific to Cbush, RBE 2 will not accommodate properties of any kind.
but i was just able to use Pbush propety (Rigid) for my RBE2 element...
Hi, it sounds great
Could you share your bulk data please? I wanna know how you did it
@tinh
i first defined RBE2 element by 1D>rigids...
Then Model Broser> create Property> Pbush> Define Property
Then Model browser > component> Property> Pbush.
Bulk Data
$ RBE2 Elements - Multiple dependent nodes$RBE2 132102 38009 123456 6871 6872 6874 6877 6883+ 6892 6913 6916 6921 6931 6932 6938 6940+ 6951 6960 6968 26057 26058 26059 26061 26063+ 26064 26065 26066 26067 26068 26070 26071 26072+ 26073 26074 26075 32110 32111RBE2 132103 38010 123456 6865 6866 6886 6895 6915+ 6927 6929 6930 6935 6936 6937 6944 6956+ 6957 6958 6959 6963 25373 25375 25377 25379+ 25380 25381 25383 25384 25385 25386 25387 25388+ 25389 25390 25392 25393 25394 25395 25396 32112+ 32113 32114 32115 32116 32117 32118 32119 32120+ 32121 32122RBE2 132104 38011 123456 7040 7042 7057 7058 7064+ 7070 7072 7073 7074 7076 7079 7081 7083+ 7085 7086 7087 25610 25612 25614 25615 25616+ 25617 25618 25619 25620 25621 25622 25623 25624+ 25625 32222 32223 32224 32225 32226 32227 32228+ RBE2 132105 38012 123456 7093 7098 7103 7104 7111+ 7113 7114 7120 7125 7132 7136 7137 7138+ 7139 7140 7141 7142 25843 25845 25848 25849+ 25850 25851 25852 25853 25855 25856 25858 25859+ 25860 25861 25862 25863 25864 32102 32103 32104+ 32105 32106 32107 32108 32109
$HMMOVE 22$ 132102THRU 132105$
$$ PBUSH Data$$$HMNAME PROP 1'pbush' 2$HWCOLOR PROP 1 4PBUSH 1 KRIGID RIGID RIGID RIGID RIGID RIGID $$
Hi Pratik, in your bulk data RBE2 has no data field referring to PBUSH #1
so actually the PBUSH is not linked to RBE2
in hypermesh you can assign property to a RBE2 component but output bulk data of RBE2 have only ID, Inode, Dofs, Dnodes
Pratik,
what is the reason to give a PBUSH property to RIGID elements?
A rigid element like RBE2 will be rigid all DoFs and RBE2 doesn't carry a PID as Tinh said.
Hi Pratik, in your bulk data RBE2 has no data field referring to PBUSH #1 so actually the PBUSH is not linked to RBE2 in hypermesh you can assign property to a RBE2 component but output bulk data of RBE2 have only ID, Inode, Dofs, Dnodes
Do you mean removing Pbush property will have no effect . Also then using Spring element with C Bush property with dof set to zero will better way to modell structutre fixed to rigid support
Yes you can remove the PBUSH, the better way to model structure fixed to rigid support is to create RBE2 at nodes of structure and apply SPC for one of nodes of the RBE2. SPC is rigid support
