Are your 'screws' modelled as pretension springs? The pretension can manifest itself as negative internal energy in the springs depending on the set up (nothing to worry about though, you should see the equivalent internal energy increase in whatever they are attached to) example below is a pre ten spring (purple curve) connected in series with a 'normal' spring during the pretension then lock phase.
Thank you for reply. Yes. Scews are having pre-tensions.
If you see attached pic which has energy plots, it shows -ve IE and TE is less than KE.
Which is not typical energy plot for impact problem.
'Total Energy' (TE) doesn't include contact energy though and that looks to be more than the difference you have between KE and TE, in fact, your CE looks too high to me, If you plot 'Total Translational Energy' (TTE, which includes TE and adds CE and HE and RKE) then it will be greater than KE alone
