🎉Community Raffle - Win $25
Join and Win
Point Mass Addition
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
When I use the admas Option in 1D, it gets created also it creates a set. If I delete the set is the admas deleted. Where can I visually see after the admas is kept.
In the model attached, the admas is added on the top most node in the column, Set number is grnodeAdmas 22.
Now, I could not find where is the input value of the mass of 60Kg that I have added in it. I wish to change it and deletion of the set gives me an error.
yours sincerely,
kartik
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    yours sincerely,
    kartik
    Also kindly explain how to remove the added point mass completely. Using delete option only deletes the node set
    Altair Employee
    OP
    Hi Kartik,
    From Utility Menu>ADMAS Manager you can review,and delete the added mass in the model/
    Altair Employee
    OP
    Hi Kartik,
    Thank you
