Submitted by LAVA on Tue, 08/25/2015 - 18:13 Hi
I want to use a different SOC for each of my ADC's but when i go to ADC settings i get this (Image attached) I am using F28335 with USBv1 please help me how to debug the same
Submitted by imatalon on Wed, 08/26/2015 - 19:23.
Unfortunately you can't do that using the F28335. It splits the 16 ADC channels to 2 banks (called sequencers) and you can actually trigger those banks. So you can only have two triggers. Newer boards do offer users the ability to trigger each channel independently, the F28335 doesn't.
Submitted by LAVA on Tue, 09/01/2015 - 09:44.
hi I found a way out it turns out that you can using the ADC interrupt handler you can trigger the ADC at the sampling of the PWM
