I have designed a patch antenna which is operated using proximity feed. After running, in POSTFEKO the realised gain was very low despite 'good' gain values. When I checked the current activity using Currents requests, I found out that only a little current is induced in the patch. I'm running FEKO 14. I have no idea what's wrong. Any help will be appreciated. Thank you.
