I need to export the no of elements present after topology optimisation or the optimised surface area of the geometry. I can export it as a CAD file and find the area and so on...
But I would like to print them into a file, maybe a .txt file so that I can all for these values in a code that I am developing.
Kindly let me know if there is a solution to this or should I obtain the information manually?
Thanks,
Suraj.R
