Submitted by Joe on Fri, 10/02/2009 - 00:04
How can i connect my TI based board with vissim/ECD?
Submitted by Anders89 on Fri, 10/02/2009 - 00:30.
1) Run Code Composer Setup and add the JTAG->Target link to CCS supported targets. If the JTAG unit does not appear in the CCS Setup list, download and install the JTAG drivers from the JTAG vendor. For example, the Spectrum Digital CCS V3 driver support is found here:http://support.spectrumdigital.com/ccs33/ 2) Save & Quit 3) Start Vissim, navigate to VisSim/DSP > > DSP Config... 4) Select the JTAG Connection from the drop down and click OK.
VisSim/ECD supports all third-party JTAG boards that CCS supports.
Submitted by duncanallen on Thu, 01/28/2010 - 05:57.
How do I do this with CCSv4? I am using a BlackHawk USB 2000 if that makes any difference.
Submitted by Anders89 on Fri, 01/29/2010 - 19:13.
You can download it here
