How to import multiplier function
Dear All:
I got a question. I want to define some multiplier functions and I want to modify the inp file rather than click in the GUI to import my multiplier function one by one.
The right screenshot is how my scripts in 'inp' file looks like. The left screenshot is the data format. After I import the inp file, the multiplier function is wrong, only one point is generated.
Would you please have a look to see if I have something wrong here?
I tried to change the file name to 'problem1.dat', 'problem1.txt', but none of them work.
Thank you very much for your help.
It looks like reading the .inp into AcuConsole is not reading the multiplier function arrays correctly. It's the same even if the multiplier function values are in the .inp itself rather than a referenced external file. So, for now, you'll need to import the multiplier function arrays manually into AcuConsole.
