Is it possible to have access to eCAP register with VisSim
Altair Forum User
Altair Forum User
Submitted by Alix on Fri, 04/23/2010 - 21:44
I want to read an optical fork mounted on a drive shaft with VisSim, and I want to estimate speed and position of the drive shaft. Using eCAP I can have access to the time between two rising edges of the fork signal, which gives me the speed (I use VisSim F280X eCAP module, which works well). Having access to the eCAP register would allow me to directly estimate the position (angle).
Is it possible to have access to the eCAP register with VisSim, and how ? I put some details in the attached drawing, to explain what eCAP register means for me.
Thanks,
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Fri, 04/23/2010 - 22:24.
    Alix, The eCAP module produces an eCAP register value at each output pin. There are 4 capture registers, one for each of the 4 events. However, you can reference any eCAP register using the VisSim extern read/write blocks as described here.
    Also, I did not see an attached file. You must click on File Attachments below the edit window when posting or editing, then Choose File' for the file, and then *Attach.
