Rigid body momentum distribution
I'am setting up a hypermesh model and I ran into two problems I could not resovle in an appropriate manner. I have a momentum at some point on an engine and 6 mounts, which are constrained on the ground.
How can I model that engine without a CAD model? We can assume the engine to be completely stiff. The attachment points of the engine should not be independent from each other. I tried to model this with rbe3 elements as you can see in the picture below, but this results in diplacement of the attachment points independent from each other.
I would be very thankful for any ideas on how to model this rigid body.
Kind regards,
alex
Hi Alex,
How are you modelling engine?
Is it using concentrated mass?
I am assuming that the mounting point should be together (for not to be independent) in such case maybe you can connect them using RBE2 elements?
0 -
Hello Prakash,
thank you for your reply. I followed your suggestion and added rbe2 elements. The problem was, that one node cannot have more than 1 rigid attached to it.
Regards,Alex
0 -
Hi Alex,
I hope you are all set now. Please let me know if you need any help. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
