Submitted by opio_001 on Tue, 02/14/2012 - 04:53
hi all, i have a spectrum digital ezdsp f28335 starter kit, and i am new with vissim, i just would like to kwon if vissim is compatible with ezdso f28335.
thaks, regards.
Submitted by Anders89 on Tue, 02/14/2012 - 20:06.
Yes, VisSim supports the entire line of C2000 products. The F283xx series is also called 'Delfino' which is how you will see it listed in the VisSim menu: Embedded > Examples > Delfino. All the Defino examples will run on the F28335 eZdsp board. The examples that use on-chip peripherals like I2C write-to-EEPROM and CAN Rx/Tx will work fine with your eZdsp board which has on-board EEPROM and CAN transceiver. Note that the F28335 controlCARDs do not have EEPROM or a CAN transceiver but some kits like the HVMOTOR-kit have a CAN transceiver.
