hey guys,
i installed hyperworks student edition and i want to simulate a beam stress analysis but when i got to the step of adding loads i didn't find pressure nor fixed options in fact many options are missing is this the way it is ? any help ?
You can add Pressure and Constraints from the Analysis Page. Please refer the below picture.
What version of student edition are you using?
Thankyou
I'm using the latest version 2017, those options aren't available no constraints, forces,moment,pressure and others more
Can you please tell me if you can setup the loads from the menu 'Setup' as shown below.
nope, only rigid walls contact surfaces and equation are shown
You are in the wrong user profile. You are in RADIOSS profile.
Please change your user profile to OptiStruct from the option as shown in below image.
YES i was ( i'm still new to the software my bad ) thank you so much Sanjay
