I want to export the mesh of cadfeko with command lines , just like the use of cadfeko_batch in the cmd.
Thank you.
You can use the Lua scripting for the export.
Press record in CADFEKO.
Do a test mesh export.
Stop the recording. Modify the recording as you want.
Play back the script.
Scripts can be executed from the command line and in non-interactive mode.
You can use the Lua scripting for the export. Press record in CADFEKO. Do a test mesh export. Stop the recording. Modify the recording as you want. Play back the script. Scripts can be executed from the command line and in non-interactive mode. <?xml version="1.0" encoding="UTF-8"?>
Thank you so much,I'll try this method.
I have solved this problem by the use of lua scripts,thanks a lot for mel's help.
