I'm trying to use Log.ExpandMacros method to get some values, assign them to a String, then output those values to a text file. What is happening is that the value returned from Log.ExpandMacros is the same value I pass as the parameter.
Dim test as String
test = Log.ExpandMacros("&[source.name]")
At this point, test is "&[source.name]", not the expansion of the macro I expected. I get the same for other macros as well. Is this expected? Is there a way to get the actual value?
