🎉Community Raffle - Win $25
Join and Win
Compose Error code 9
User: "Altair Forum User"
Updated by Altair Forum User
I recently installed Compost, I added the environment variable as asked. but am still getting an error code 9, feature not found. How do I fix this?
This is the screenshot of the error i am getting and the environment variable I added.
1 - 4 of 41
    User: "Rahul_P1"
    Updated by Rahul_P1
    You can remove the environment variable and place the license file directly in the security folder,
    Use windows folder options > unhide known extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,
    You need to confirm if the Ethernet address in the license file is the correct one and matches the one in your machine.
    When you open the license file in a text editor you will see an Ethernet address there in a line that says 'ETHERNET =
    The Ethernet ID is the ID of your machine which is exactly 12 hexadecimal numbers. For example D4WRF478F398
    Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection:
    The listed physical address under Ethernet adapter local area connection should be used to generate the license file, if there is no listing of Ethernet adapter local area connection, the address under Wireless Adapter LAN Wifi must be used.
    That means if the address provided as above does not match the one in the license file, please request for the license file again with the correct Ethernet ID.
    OP
    How do I request for the liscence file again and what do you mean request with the correct Ethernet ID , can you please elaborate.
    User: "Rahul_P1"
    Updated by Rahul_P1
    You can request again here https://studentedition.altair.com/
    OP
    Error 9 is one of the problem that I have faced from long time but  I did not found the solution for it yet. Again for last few days I was facing a different error that is Error Code 0x80072F8F it was a very complicated error and I was unable to solve those but then I have come across one of the website which properly shows each and every thing in a very easy and simple way. I would suggest you to go through the website and give a solution of your topic like it's given on the link above.
