I would like to investigate the system behavior of a Hypermesh model in Hyperstudy. The FE model consists of various components or assemblies. I have parameterized the .fem file and performed a nominal run. Now, I would like to use the .h3d file to output the maximum stress for specific components or assemblies. Unfortunately, so far, I have only managed to select a range using the First and Last request. Is there a way in Hyperstudy to select multiple elements in an Output Response that do not have a contiguous element numbering or even output the maximum stresses across components or assemblies?
Thank you for your help.
