Setting up License Server on Gentoo Linux
Hi there,
Have been trying to install the License server for Altair Hyperworks onto a Gentoo Linux based server.
However, during the terminal/console based installation (our server does not have a GUI), the error messages come up saying the License manager failed to install, and then
that the service failed to start.
Am wondering what the solution to this problem could be. I tried to check the XML log file that it talks about at the end of the installer, but I could not see where the problem lies.
The altairlmxd script was also not placed in /etc/init.d, and so there is no way to really start the license server/service.
We are running Gentoo on all the computers in our computer lab, and also plan to use Hyperworks on a Gentoo computer as well. The server where we are trying to install the
license server is running Gentoo as well.
Our goal is to have the license server up and running so we can then install Hyperworks...
Please advise...
Below is the output of the installer from the terminal, when we attempted to install the license server:
========================================================================= ====== Altair License Server 12.2.0 (created with InstallAnywhere) ------------------------------------------------------------------------- ------ Preparing CONSOLE Mode Installation... ========================================================================= ====== Introduction ------------ InstallAnywhere will guide you through the installation of Altair License Server 12.2.0. It is strongly recommended that you quit all programs before continuing with this installation. Respond to each prompt to proceed to the next step in the installation. If you want to change something on a previous step, type 'back'. You may cancel this installation at any time by typing 'quit'. PRESS <ENTER> TO CONTINUE: ========================================================================= ====== Choose Install Folder --------------------- Please choose a destination folder for this installation. Installation Directory: Default Install Folder: /usr/local/altair/licensing12.2 ENTER AN ABSOLUTE PATH, OR PRESS <ENTER> TO ACCEPT THE DEFAULT : /home/remote/Altair/License INSTALL FOLDER IS: /home/remote/Altair/License IS THIS CORRECT? (Y/N): y ========================================================================= ====== License File Availability ------------------------- Do you have an existing license file? If yes, please enter the name of the license file with the complete path. A copy will be made and kept under the installation directory: /home/remote/Altair/License ->1- Yes 2- No ENTER THE NUMBER FOR YOUR CHOICE, OR PRESS <ENTER> TO ACCEPT THE DEFAULT:: 1 ========================================================================= ====== Existing license file location ------------------------------ Please enter the name of the existing license file that you have with the complete path. License File Path: (Default: ): ALCD_UTOR_20170131_294686.dat ========================================================================= ====== Pre-Installation Summary ------------------------ Please Review the Following Before Continuing: Product Name: Altair License Server 12.2.0 Install Folder: /home/remote/Altair/License Disk Space Information (for Installation Target): Required: 143,929,482 Bytes Available: 340,196,233,216 Bytes PRESS <ENTER> TO CONTINUE: ========================================================================= ====== Installing... ------------- [==================|==================|==================|============== ====] [------------------|------------------|------------------|-------------- ----] ========================================================================= ====== Installing Linux Desktop Icons ------------------------------ Installtion of desktop icons failed. The installation of desktop icons on the machine has failed. Please check the log for details on the same. ->1- OK 2- Cancel ENTER THE NUMBER OF THE DESIRED CHOICE, OR PRESS <ENTER> TO ACCEPT THE DEFAULT: ========================================================================= ====== Install Licensing Service ------------------------- The Altair Licensing Service failed to install. Please click 'OK' to proceed with installation or click 'Cancel' to cancel and exit installation. ->1- OK 2- Cancel ENTER THE NUMBER OF THE DESIRED CHOICE, OR PRESS <ENTER> TO ACCEPT THE DEFAULT: ========================================================================= ====== Start Licensing Service ----------------------- The Altair Licensing Service failed to start. Please click 'OK' to proceed with installation or click 'Cancel' to cancel and exit installation. ->1- OK 2- Cancel ENTER THE NUMBER OF THE DESIRED CHOICE, OR PRESS <ENTER> TO ACCEPT THE DEFAULT: ========================================================================= ====== Installation Complete --------------------- Congratulations. Altair License Server 12.2.0 has been successfully installed to: /home/remote/Altair/License For details, please check the installer log file under /home/remote/Altair/License/uninstall/logs/ after quitting the installer
You found never Gentoo within supported OS of Hyperworks software!
For licence server, go for RHEL (paied) or CentOS (free). CentOS is binary compatible to RHEL which is supported by Altair.
Our license server runs since several year under CentOS no problem.
For workstation, you want to work with Hyperwork under Gentoo? I would like to say 'Good luck' to you /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
0 -
Your local appllication engineer in Canada should already be in touch with you and will help you resolve the issue.
0 -
We managed to get this to work eventually, and successfully. We have a Gentoo-hosted license server and running the hyperworks software on Windows and Linux systems.
@Rahul Ponginan - Thanks, our local agent did get in touch with us...
