Altair RISE
Nominate Yourself Now!
HyperWorks 2022 crashing when starting
User: "Rasmus"
Altair Community Member
Updated by Rasmus
When I try to start HyperWorks 2022.2 it just crashes. Sometimes without any explanation other times with the issue shown in attachment. It also happens when I try to open a file. I have tired re-installing the program without any luck. Have anyone had the same issue and solved it?
Best,
Rasmus
1 - 6 of 61
    User: "Chayan"
    Updated by Chayan
    Hi Rasmus,
    You can try the following steps to see if they remedy your issue:
    1: Run hwcleanup. This will remove the session files that HM creates and uses. Corrupt session files could cause crashes.
    2: Update Graphics Drivers: We have seen older graphics drivers will give users problems. DO a clean reinstall of the graphics drivers.
    3: Check Antivirus software: See if your antivirus software, is locking down the machine too tight, and not letting HyperWorks launch.
    User: "Adrian  Schrader"
    Updated by Adrian Schrader
    I have had the same issue as you, with the same error message (sometimes appearing, sometimes not), with HW crashing on launch. Version: 22.3.1
    So far I have been able to isolate the issue to be only under the following conditions:
    • Cicso Webex is running, AND
    • I am logged into Cisco Webex.
    If I am logged out of Webex, HW launches without crashing.
    I have not been able to diagnose the issue any further than this. Hopefully someone has some clues what to try next (besides removing Webex completely, it's needed for work).
    User: "Rasmus"
    OP
    Updated by Rasmus
    It turned out to be a problem with my Windows installation. After re-installing the whole thing, all worked fine.
    User: "Nam Tran Dai"
    Updated by Nam Tran Dai
    Hi
    So i have the same problem but without the error message. When i opened HW, it just didn't showed up, and nothing happened.
    I had asked for help and one of the member of Altair told me that i should shut down Webex in order not to interface HW. But i'm sure that i have Webex on my laptop.
    Any advice?
    Hi
    Any advice?
    An update on my situation:
    Updating to the latest Hyperworks (2023) has resolved my issue and I’m able to launch all the softwares without any conflict with Webex.
    I had deleted and recreated my user profile prior to this for another issue, but I’m fairly certain the software update is what fixed this issue, I believe it was a known conflict/bug for Altair.
    Please can u tell me how to update to the latest Hyperwork 2023 version? I'm currently using 2022.3 and it doesn't respond when i turn it on
    By the way, i'm using the Student Edition
    Many thanks
