Hello Lionel,
I get the same malformed error. Sorry about this. Could you send the code?
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="85"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Att1,Att2 michael,1 Lionel,2 Scott,3 Brian,4 Varun,5 Jacob,6 Martin,7 Ingo,8 Kayman,9"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="179" y="187"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Att1 Lionel Ingo Brian"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="9.9.002" expanded="true" height="82" name="Set Role" width="90" x="447" y="187"> <parameter key="attribute_name" value="Att1"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="9.9.002" expanded="true" height="103" name="Multiply (2)" width="90" x="313" y="34"/> <operator activated="true" class="set_role" compatibility="9.9.002" expanded="true" height="82" name="Set Role (3)" width="90" x="648" y="34"> <parameter key="attribute_name" value="Att1"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="set_role" compatibility="9.9.002" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="34"> <parameter key="attribute_name" value="Att1"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="set_minus" compatibility="9.9.002" expanded="true" height="82" name="Set Minus" width="90" x="581" y="187"/> <operator activated="true" class="set_minus" compatibility="9.9.002" expanded="true" height="82" name="Set Minus (2)" width="90" x="782" y="136"/> <connect from_op="Create ExampleSet" from_port="output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Set Minus" to_port="subtrahend"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Set Minus (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Set Minus" to_port="example set input"/> <connect from_op="Set Minus" from_port="example set output" to_op="Set Minus (2)" to_port="subtrahend"/> <connect from_op="Set Minus (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
