How to fix the loss of attribute sorting / reordering after applying an ML operator?
Mike0985
Mike0985 New Altair Community Member
Dear all,
I have a reordering and sorting of attributes in my process before applying a machine learning model. When I run the process, I will lose the reordering & sorting directly after the machine learning model operator, e.g. Naive Bayes. I also had the same issue with the normalization operator. For now, I put the reorder & sort operator off the process but I still need them.
How can I fix this issue?
Kind regards
Michael
Welcome!
Best Answers
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi Michael,
    keep in mind that the order of attributes does not matter in rapidminer. Unlike other tools we identify our columns by name, not by position. The only reason to order them is usually data export. You can then use the Reorder Attributes operator for that.
    Best,
    Martin
  • BalazsBaranyRM
    BalazsBaranyRM New Altair Community Member
    Answer ✓
    Hi Michael,
    if you need the data in the original order and attribute order, create a copy with Multiply and then join the later results to that table. This should mostly keep the data in order and add the new columns at the end.
    Balázs
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi Michael,
    Best,
    Martin
  • BalazsBaranyRM
    Answer ✓
    Hi Michael,
    Balázs
  • Mike0985
    @mschmitz @BalazsBarany thank you very much :-).
Welcome!
Welcome!
