Magnitude & Phase output for FFT Function with Windowing
User: "Debdatta_Sen"
Updated by Debdatta_Sen
Hi all,
I have a time domain curve which I would like to convert into frequency domain.
By doing so I would like to obtain the magnitude and phase output from the curve.
I need the Windowing function as well. Something like what fft hanning does in HyperGraph.
Is there a similar function in Compose?
The output I need should have both Magnitude and Phase components, something like this:
<?xml version="1.0" encoding="UTF-8"?>grafik.thumb.png.51dde0ae7d300785547232d9ac411b5b.png
1 - 2 of 21
    User: "L Moretti"
    New Altair Community Member
    Updated by L Moretti
    Hello Debdatta,
    you can use the user defined function (attached to this reply) with this syntax:
    [AmpFFT,PhFFT,f] = FFTeval(s,Fs);
    s: your signal values
    Fs: sampling frequency
    AmpFFT: apmlitude of the single sided spectrum
    PhFFT: Phase of the single sided spectrum
    f: frquency vector
    you can then plot your results:
    figure()
    plot(f,AmpFFT)
    figure()
    plot(f,PhFFT)
    Of course you can also apply windows to your signal. There are many built windows ready to be used.
    Your script will be:
    w = hann(numel(s),'periodic');  %window
    s = s .* w;  % windowing
    Other windows you can use:  hamming, kaiser, blackman... (just look inside the SignalProcessing library)
    Hope it helps,
    Lorenzo
    User: "manoj kandukuri"
    Updated by manoj kandukuri
    Hi Debdatta,
    You can use 'real' & 'angle' commands to get magnitude and phase of fft signal
    real(ft)
    angle(ft)
    thanks,
    Manoj kandukuri
