Hello All,
So, I've been able to run all the Keras samples in the Rapidminer repository except for the s&p-500-regression. I have the below error message which I think has something to do with Java or the operators being used. It would be great if someone can help on this!
Thanks!
- Exception: com.rapidminer.operator.OperatorException
- Message: Script terminated abnormally.
- Stack trace:
- com.rapidminer.operator.scripting.AbstractScriptRunner.run(AbstractScriptRunner.java:166)
- com.rapidminer.extension.keras.general.Sequential.doWork(Sequential.java:436)
- com.rapidminer.operator.Operator.execute(Operator.java:1022)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:806)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:801)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:801)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
- com.rapidminer.Process.executeRoot(Process.java:1464)
- com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
- com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
- java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
- java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
- java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
- java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
