<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="648" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Q1_19,Q2_19,Q3_19,Q4_19,Q1_20,Q2_20,Q3_20,variable 1,1,1,1,1,0,0,a 1,1,1,1,1,0,0,b 1,1,1,1,1,0,0,c 1,1,1,1,1,0,0,d 1,1,1,1,1,0,0,e 1,1,1,1,1,0,0,f 1,0,1,1,0,0,0,g 1,1,1,1,1,0,0,h 1,1,1,1,1,0,0,i 1,1,1,1,1,0,0,j 1,1,1,1,1,0,0,k"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="648" y="136"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Q1S_Y1S,Q2S_Y2S,Q3S_Y3S,Q4S_Y4S Q4_17,Q3_17,Q2_17,Q1_17 Q4_17,Q3_17,Q2_17,Q1_17 Q4_17,Q3_17,Q2_17,Q1_17 Q4_17,Q3_17,Q2_17,Q1_17 Q1_18,Q4_17,Q3_17,Q2_17 Q4_17,Q3_17,Q2_17,Q1_17 Q1_18,Q4_17,Q3_17,Q2_17 Q4_17,Q3_17,Q2_17,Q1_17 Q4_17,Q3_17,Q2_17,Q1_17"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_port="result 1"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
